Universal Gravity Circular Orbit
To find the radius of a circular orbit around Earth where acceleration is 0.1g, the gravitational acceleration g is given as 9.8 m/s². The discussion highlights an incorrect method involving logarithms, leading to an estimated radius of 21,000 m, which is deemed inaccurate. The correct approach utilizes the relationship r² = 10R², resulting in r being √10 times the Earth's radius. The reference from Halliday and Resnick suggests a radius of 6.37 x 10^6 m, leading to a calculated orbit radius of approximately 20 x 10^6 m. The conversation emphasizes the importance of using the correct equations for accurate orbital radius calculations.
The_Scorpion
What is the radius of a circular orbit about the Earth where the acceleration is 0.1g?
g=9.8m/s^2
F=(Gmm)/r^2
Radius of Earth= 6.38x103 km
Mass of Earth= 5.98x10^24 m/s
I said 1/(2^x)=1/10 then did log2(10)=x and solved for x getting 3.3 Earth radiuses. I multiplied that by the radius of the Earth and got 21,000 m. This was obviously the wrong method.
Your method seems correct, but the equations seems all messed up (not sure why you use logs to the base 2?):
r2 = 10 R2
so that
r = √10 R
Your answer seems sligthly off.
Also Halliday and Resnick lists R as 6.37 which then gives r as 20 x 106 m.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
