Solving Unseparable O.D.E. xyy`= 2y^2 +4x^2
  • Thread starter asdf1
In summary, another O.D.E. question: yy`= 2y^2 +4x^2 = r(x) when x=y/x also unseparable...I`m a bit rusty on D.E.'s, but you can write it as: y'=2(y/x)+4(x/y)IIRC, whenever you have y'=F(y/x), the equation also called homogeneous (different from the homogeneous linear ODE definition), this one is invariant under 'zoom'. Checking if it's separable should indeed always be the first you do and when it's not, try to see if you can make it separable
asdf1
734
xyy`= 2y^2 +4x^2
also unseparable...
[tex]y'=2(y/x)+4(x/y)[/tex]
If you make the subsitution z=y/x, the equation becomes:
[tex]z+xz'=2z+4/z[/tex]
or
[tex]xz'=z+4/z[/tex]
which is separable.
it's separable, use v=y/x
why'd you think of v=y/x?
Galileo explained. It's because the DE is homogeneous (not with the 0 constant, but with the sum of all exponents of all terms is constant (here 2). You can then divide so the DE becomes a function of (y/x). Susbtitution will make it separable.
so the first step when you see an O.D.E you have to check if it's separable
=> if not, then check if it's homogeneous, and use that substitution...
thanks! :)
Checking if it's separable should indeed always be the first you do and when it's not, try to see if you can make it separable with a substitution.
The substitution used here a very common one.
what are the most common substitutions used?
Well y = v(x)x is a common one and if I recall correctly, for second order isobaric equations you can make the substitution y = vx^m if there is a single value of m which makes the equation dimensionally consistent (you assign weights to y, dy, x and dx).
ok~ thanks! :)
hmmm... here's my work~
(i forgot to include that the original condition is y(2)=4, sorry about that!)
y`= 2y/x+4x/y
suppose y=vx
=>v=y/x
so y`=v+v`x
=> v+xv`=2v +4/v
=> v`x=v+4/v
=> v`x=(v^2 +4)/v
=> v/(v^2 +4)dv=dx
=> 1/2[dv^2/(v^2 +4)] =dx
=> 1/2ln[absolute value (v^2 +4)] =x+ c`
=> ln[absolute value (y^2/(x^2) +4)]=2x+c`
=> y^2/(x^2) +4 =e^(2x +c`)
=> y^2 +4x^2 =c(x^2)*[e^(2x)]
=> y^2=c(x^2)*[e^(2x)]-4x^2
now my problem is that when you take the square root on both sides of the equations, the right side should have a positive and negative root, but the correct answer should only have a positive square root~
why?
btw, what is meant by the different homogeneous definitions and "zoom"?
y`= 2y/x+4x/y
suppose y=vx
=>v=y/x
so y`=v+v`x
=> v+xv`=2v +4/v
=> v`x=v+4/v
=> v`x=(v^2 +4)/v
=> v/(v^2 +4)dv=dx
Whoopsie, you've lost an x.
why?
The actual answer also needs a square root since you'll get a relation between y^2 and x. Now if this equation is true both the positive and negative square roots must be valid solutions to the ODE, but a little bit of thought shows that no more than one can fit the same boundary condition (y(2)=4)
A linear DE of, say, second order:
[tex]y''+A(x)y'+B(x)y=r(x)[/tex]
is called homogeneous if r(x)=0. Your ODE is a also called homogeneous, but it's in a different context, so it naturally hasn't the same meaning.
Since the ODE can be written in terms of y/x. If we make the change of variables [itex]\hat y=ay[/itex] and [itex]\hat x=ax[/itex] for some positive a. So that we're scaling the y and x-axes by the same amount (this is what I meant by zoom), the ODE looks the same, since [itex]\hat y/\hat x=y/x[/itex].
thank you very much! :)
i'll try and be more careful on my calculations~
What is an unseparable O.D.E?
An unseparable O.D.E (ordinary differential equation) is a type of differential equation where the dependent variable and its derivative cannot be separated on different sides of the equation. This means that the equation cannot be solved using traditional separation of variables methods.
What is the difference between separable and unseparable O.D.E.s?
The main difference between separable and unseparable O.D.E.s is in the way their variables can be separated. In a separable O.D.E, the dependent variable and its derivative can be isolated on different sides of the equation, making it easier to solve. In an unseparable O.D.E, the dependent variable and its derivative cannot be separated, making it more difficult to solve.
How do you approach solving an unseparable O.D.E?
To solve an unseparable O.D.E, you can use a variety of methods such as substitution, integration by parts, or power series. It is important to carefully examine the equation and try different methods to find the most suitable approach.
What are some common techniques used to solve unseparable O.D.E.s?
Some common techniques used to solve unseparable O.D.E.s include substitution, integration by parts, and power series. These methods involve manipulating the equation to make it separable or using advanced mathematical techniques to find a solution.
Why are unseparable O.D.E.s important in science?
Unseparable O.D.E.s are important in science because they arise in many real-world situations, particularly in physics and engineering. By solving these equations, scientists and engineers can better understand and predict the behavior of complex systems. Additionally, the techniques used to solve unseparable O.D.E.s can be applied to other types of mathematical problems.
  • General Math
