Unsure About Island Temperatures? Unlock the Answers Here!
  • Thread starter Thread starter DevilDoc
    Confused
The discussion revolves around the specific heat of water and its role in moderating temperatures on islands, with a consensus that water's high specific heat allows it to absorb solar energy without significant temperature fluctuations. Participants also tackle a math problem regarding the temperature change of water when it absorbs heat, with one individual calculating a change of approximately 0.597 degrees Celsius. Another problem involves calculating the speed of a wave based on its frequency and wavelength, leading to a debate about the correct application of the formula and unit conversions. Additionally, there is curiosity about the behavior of circular wavefronts and whether their spacing changes as they propagate. Overall, the conversation emphasizes understanding specific heat, wave dynamics, and the application of mathematical principles in physics.
DevilDoc
Just confused :confused: with the questions. I can't find the answer anywere.
The moderate temperatures of islands through out the world has much to do with water's? I'm thinking high specific heat or reflection of solar radiation but not sure.
Specific heat is the answer, the oceans absorb the energy from the sun and do not cool down very quickly.
Additional help.
I'm not really good in math. Please help, not sure If got the right answer.
1 ) 2000 grams of water absorbs 5000 J of heat. If the specific heat of water is 1 cal/g C. What is the change of temperature of the water?
My answer is: 0.595 C.
2) When a tiger drinks water, it ames portion of water oscillating up and down four complete cycles per second. As the water wave spreds, the wavelength is 5 CM. What is the wave's speed?
My answer is: 1.25 m/s.
I agree with the temperature change--actually, I got 0.597 degrees using 4.186 Joules = 1 calorie.
For the speed, are you using wavelength*frequency = speed ? Notice that the wavelength is in centimeters; I got 0.2 m/s.
Another question: do circular wavefronts on the water's surface maintain equal spacing as they spread out? The tiger's tongue is oscillating at a constant rate--so a bob placed any distance from the center would bob up and down at a constant (temporal) rate--but do the ripple peaks get closer together or further apart as you go out? I'm just wondering if it's really fair to talk about the 'wavelength' for such a mode of propagation.
P
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
