USB to FireWire Adapter: Do They Exist & Are They Reliable?
  • Thread starter Thread starter Simfish
    Adapter Usb
A user encountered compatibility issues with a LaCie external hard drive that only has a FireWire port, while their laptop lacks FireWire connectivity. It was clarified that USB/FireWire adapters do not exist due to the incompatibility of the two technologies. The recommended solutions include exchanging the external hard drive for a USB2 model or using a PCMCIA or ExpressCard with a FireWire interface. The discussion revealed that the user's laptop, a Gateway MT6451, actually has a FireWire port, but it is a 4-pin version, requiring a specific 4-pin to 6-pin cable to connect to the external hard drive. The conversation also touched on the distinction between male and female connectors, emphasizing the need for male-to-male cables for most computer connections.
Simfish
So I just bought a Lacie external hard drive. Problem is - my laptop doesn't have firewire - and my external hard drive only has a firewire port. So do good USB/firewire adapters exist? I searched on the Internet for some - but there don't seem to be many of them. Does the adapter allow a firewire software to be connected to a laptop with only USB ports?
Thanks!
For some reason, many of the adapters have ratings of 1 or 2 stars. It could be selection bias in that people are likely to submit negative reviews of products that they can't get to work - but the fact that so many products have so few stars worries me...
Computer science news on Phys.org
Thanks!
There is no such thing as a USB/Firewire adapter as the interfaces are not compatible.
I suggest you exchange it for a USB2 external hard drive and preferably one that also has an eSata connection.
Alternatively, you can buy a PCMCIA or express card with a firewire interface for your laptop.
Firewire and USB are two different [bus] communication technologies. You can't simply switch a firewire device into a usb port. As a matter of fact, I don't believe that there exist any such adapter (remember two different technologies).
Maybe you can get some sort of hub (dual firewire/usb hub).
Edit: Got beaten to it :)
Simfishy said:
PCMCIA cards are a type of memory card
No they are not.
Practically all laptops either have a PCMCIA card interface or a new express interface (the new laptops).
What's the make and model of your laptop?
Here is a list of http://computers.pricegrabber.com/usb-firewire-devices/p/405/popup1[
But doesn't the Wikipedia article say that PCMCIA cards are a type of memory card format? (PCMCIA, secure digital, memory stick, and compact flash are all categorized as such).
hmm - http://en.wikipedia.org/wiki/Comparison_of_memory_cards doesn't list PCMCIA - it only lists the others, even though the above-mentioned Wikipedia article does. (of course I can't always trust Wikipedia - but it generally seems accurate for computer-related info)
Laptop is a Gateway MT6451 notebook.
hmm - the website lists "Digital Media Manager™
4-in-1 Digital Media Manager™ (Memory Stick®,
Memory Stick Pro®, MultiMediaCard™, Secure Digital™) " under Digital Media Manager - though my box lists them as memory card readers. Further down the website mentions "Expansion Slot
PCMCIA - Type I or Type II " - though my computer box doesn't list PCMCIA...
Hm, I just looked at the computer diagram - it has a PC Card slot and a memory card reader. So I'd need a firewire to PC card slot interface. So a Firewire cardbus adapter should fit in the slot of PC Card Types I and II almost all the time -right?
Hold on Simfishy, it seems your laptop already has a firewire (IEEE 1394) port!
http://www.gateway.com/retail/mt6451.php
Hmm - my firewire thingie is too big to fit into that port...
EDIT: 6-pin connector - laptop only has 4-pin port.
FireWire connectors come in 4- and 6-pin versions (the 6-pin provides power, while the 4-pin does not). Your laptop may (oddly enough) have a 4-pin connector, meaning you will need to use a 4-pin cable. What symbol or lettering is above the port?
- Warren
They actually come in two formats.
All you need is a little connector to convert to the small format. For a few bucks you should be up and running. :smile:
Warren beat me to it.
Okay I see. So I'd need a cable that is 4-pin on one side, and 6-pin on another, right?
If your hard drive has a 6-pin connector, you'll need a cable with a 6-pin connector on one end. If your laptop has a 4-pin connector, then you'll need a cable with a 4-pin connector on the other end. You can buy 6-6 cables, 4-4 cables, and 4-6 cables. As MeJennifer said, you can also buy little adapters, but you might find a cable with the correct connector to be more stable.
- Warren
Okay - thanks for all of the help! :)
umm... what's the difference between a male and a female cable?
Male connectors go... inside female connectors. No explanation is necessary, I hope, for what this means.
Virtually all connectors on computers and peripherals are female. Thus, you almost always need a male-to-male cable. You should be able to just look at the connectors on your devices and choose the appropriate cable.
- Warren
