Use DE to show error percentage
  • Thread starter Thread starter adomad123
    Error
adomad123
Use Differentials to show that an error of 2% in the measurement of the side of a square results in an error of approximately 4% in the calculation of the area
I'm using Area =(sΔx)^2
Using Δx=0.02,
Area= s^{2}0.02^{2} =s^{2}/2500=0.04%\timess^{2}
This is incorrect. The formula for area is A = s2. The differential of the area would be dA = (dA/ds) * ds ≈ dA/ds * Δs.
Don't confuse yourself by using two variables for the length of a side of the square. You shouldn't have both s and Δx in your work.
adomad123 said:
Using Δx=0.02,
Using Δx=0.02,
Do you really not know the difference between 4% and .04% ?
i know... i got it wrong... hence I'm asking for help.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
