Use Differentiation to Find a Power Series Representation for:
4 replies · 9K views · last reply
knowLittle
for
a.) f(x) =1/ ( (1+x)^2 )
what is the radius of convergence?
b.) Use part a.) to find a power series for
f(x)=1/ ( (1+x)^3)
c.) Use part b.) to find a power series for
f(x) =x^2 /( (1+x)^3)
I want to check my work.
I used properties of functions defined by power series.
a.)
## \dfrac {d} {dx}\left[ \left( -1\right) \left( 1+x\right) ^{-1}\right] =\sum _{n=0}\left( -1\right) \left( -1\right) ^{n}x^{n}##
after differentiating:
1/ ( (1+x)^2) =SUM[ -n x^(n-1) (-1)^n ]
b.)
##\dfrac {d} {dx}\left[ \left( 1+x\right) ^{-2}\right] =\dfrac {d} {dx}\left[ \sum _{n=0}-nx^{n-1}\left( -1\right) ^{n}\right]##
Differentiating:
2/( (1+x)^3)= SUM [ n(n-1) x^(n-2) (-1)^n ], and multiplying both sides by (1/2) yields the desired fuction.
c.)
Only multiply both sides by x^2 and the desired function is found.
Is this correct?
Thank you.
For part a, the resulting series after differentiation is correct, assuming your lower bound of summation is n=1. Otherwise, the Taylor series is SUM[(-1)^n (n+1) x^n), and the lower bound is n=0. To find radius of convergence, I would suggest Ratio test.
In part b, your process is correct, but the series that you use from part a is incorrect (see above). Also, both sides should be multiplied by -1/2.
In part c, the process is correct. It may be easier to check your work with series using http://wolframalpha.com. Make sure you take note of the bounds of integration, since having the wrong ones changes your sum.
Why do we need to change the indexing? Does it have to do with :
f(x)=a0+a1(x-c)+ a2(x-c)^2 + a3(x-c)^3+...=SUM{n=0 to infinity [an (x-c)^n ]}
knowLittle said:
for
f(x)=1/ ( (1+x)^3)
a.)
The above line should read:
[itex]\displaystyle \dfrac {d} {dx}\left[ \left( -1\right) \left( 1+x\right) ^{-1}\right] =\dfrac {d} {dx}\left[ \ \sum _{n=0}^{\infty}\left( -1\right) \left( -1\right) ^{n}x^{n}\ \right][/itex]​
Which gives
[itex]\displaystyle \left( 1+x\right) ^{-2} =\sum _{n=1}^{\infty}-nx^{n-1}\left( -1\right) ^{n}[/itex]​
You didn't answer: "what is the radius of convergence?"
b.)
Differentiating:
c.)
Is this correct?
Thank you.
