Use separation of variables to find particular solutions
Dragonfall
"Use separation of variables to find particular solutions of
u_t-u_{xx}-2u_x=0, 1<x<2, 0<t, u(1,t)=u(2,t)=0
hint: change coordinates"
I can't find the solution. The equation seems already separated, so all I need to do is to find a change of variables, I think. But I can't find one that works.
You're looking at it the wrong way.
It's not a change of variables that's wanted, but separation of variables.
Remember this ?
\frac{dy}{dx} = \frac{y}{x}
separate the variables
\frac{dy}{y} = \frac{dx}{x}
now integrate
\int\frac{dy}{y} = \int\frac{dx}{x}
ln(y) = ln(x) + c
You are expected to do something similar.
First of all, you assume a solution of the form u(x,t) = f(x)g(t)
Now substitute that into your original pde and apply separation of variables.
You should end up with functions of x on one side of the equals sign and functions of t on the other side.
Since the lhs is a function of x and the rhs is a function of t, then the only way they (the two functions) can be equal to each other is to set them both equal to the same constant value. i.e. lhs = C and rhs = C
You now have two independent pdes, (in fact, now they are ode's) one in x and one in t, that you can solve separately.
Then you need to review what "separation of variables" means for partial differential equations.
Write u(x,t)= X(x)T(t). That is, X is a function of x only, T a function of t only. The the differential equation becomes
XT'- TX"- 2TX'= 0. Divide both sides by XT to get
\frac{T'}{T}- \frac{X"}{X}- \frac{2X'}{X}= 0
or
\frac{T'}{T}= \frac{X"- 2X'}{X}
Since the left side depends on t only and the right side depends on x only the only way they can be equal (for all x and t) is if each side is a constant:
\frac{T'}{T}= \alpha
so that T'= \alpha T
and
\frac{X"- 2X'}= \alpha
so that X"- 2X'= \alpha X
where \alpha is some unknown constant. The general solution will typically be a sum of such things.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
