Use Stokes's on Line Integral to Show Path Independence
sikrut
Use Stokes's theorem to show that line integral of ##\vec{F}(\vec{r})## over an curve ##L##, given by ##\int_L \vec{F}(\vec{r}) d\vec{r}##, depends only on the start and endpoint of ##L##, but not on the trajectory of ##L## between those two points.
Hint: Consider two different curves, ##L## and ##M##, say, which share a common start and endpoint. Construct from them a closed curve ##C## to which Stokes's theorem can be applied.
$$\vec{F}(\vec{r}) \equiv [F_x(\vec{r}), F_y(\vec{r}), F_z(\vec{r})] = [2z^2, 3z^2, (4x+6y)z] \rightarrow where \rightarrow \vec{r} \equiv [x,y,z].$$
First, you need to remember that Stoke's theorem says that $$\iint\limits_S curl( \vec{F} ) d \vec{S} = \oint\limits_C \vec{F} d \vec{r}$$ You need to compute ##curl( \vec{F})## and show that it is the zero vector. This would mean that any closed line integral will be zero. This makes the integral over the path ##C## zero, which forces the two line integrals ##\int\limits_L \vec{F} d\vec{r}## and ##\int\limits_M \vec{F} d \vec{r}## to be equal.
Good Luck!
It's not necessarily the curl of F that needs to be zero, but the integration over the circumscribed area of the curl dotted into an element of normal area.
this is true, but I think if the curl is nonzero at some point then you could find a surface that makes the surface integral nonzero (you would need some sort of continuity assumption to prove this). Since this problem is talking about an arbitrary curve, L, I believe the only possibility is to show that the curl itself is zero.
I could imagine, however, a problem stated "for an arbitrary path on the surface, S, show that..." in which the curl isn't zero, but the same property holds.
Consider a single-turn copper coil with a mixture of ∂B/∂t of both polarities thruout its area. Curl of the E field = -∂B/∂t could be nonzero everywhere within its planar area but ∫curl E*dA = 0 is entirely possible, so that the circulation of E (the emf) around the coil would be zero too.
Of course, what you say is entirely correct for a lamellar field like gravity or electrostatic E field.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
