Use trigonometric substitution to verify
celeramo
Using trigonometric substitution, verify that
\int \sqrt{a^2[-t^2}dt (INTEGRAL FROM 0 TO \pi)=(1/2)a^2sin^{-1}(x/a)+(1/2)x\sqrt{a^2-x^2
Sorry it doesn't seem to want to allow me to place superscript inside a square root. but inside the first sq. root is a2-t2 and the second sq. root contains a2-x2
\sqrt{a^2-x^2}
x=asin(\theta)
-(\pi/2) \leq \theta \leq (\pi/2)
replacing x with asin\theta in the original integral
\int\sqrt{a^2-(asin^2\theta}dt
multiply and factor out. Change 1-sin^2\theta to cos^2\theta
replace dt with dt=(-a)cos\theta d\theta because t=asin\theta
End up with
\int (a)(cos\theta)(-a)(cos\theta)d\theta
Combine and get
-\int a2cos2\theta d\theta
At this point I considered pulling the a2 out in front since, unless I'm confused, it represents a constant and changing cos2\theta to 1-sin2\theta but that hasn't seemed to get me any close. Any help would be much appreciated or if I've made a mistake already identifying that for me would be excellent. Please and thank you all.
No, changing cos^2(theta) to sin^2(theta) doesn't help much. But using a double angle formula does. Change it to (1+cos(2*theta))/2
Thanks a lot.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
