Use vibration to calculate mass in space
An astronaut in space can calculate mass using a vibrating chair attached to a spring with a known spring constant of 1200 N/m, an amplitude of 0.50 m, and a speed of 2.0 m/s at equilibrium. The equation of motion for simple harmonic motion can be applied, with the general solution incorporating these known values to derive the mass. An alternative method involves timing the oscillation period with a stopwatch to determine the frequency, which can then be used to calculate mass using the spring constant. The discussion emphasizes the importance of understanding simple harmonic motion principles to approach the problem effectively. Overall, grasping these concepts is essential for solving the mass calculation in this scenario.
pchase0
an astronaut in space sits on a chair that vibrates horizontally at the end of a spring. the spring has a 1200-N/m spring constant, the amplitude of vibration is 0.50 m and the speed of the chair as it passes through equilibrium is 2.0 m/s.
also devise another method to determine the mass, you know the spring constant of the spring-seat (1200-N/m) and the mass of the vibrating seat on which she sits. you also have a stop watch. describe the method and do a sample calculation
so what have you done? Don't know any girl astronauts?
i don't know how to approach either
Forget the girl, what do you know about simple harmonic motion?
You have a mass vibrating on the end of a spring, where you know the spring constant, the amplitude of vibration, and the speed when the chair passes through equilibrium. Write the equation of motion and the general solution, then express each of the known conditions in terms of the general solution, and see if you can find the mass of the chair and occupant (male or female) from what results.
im still lost on where to even begin
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
