Using a pedulum to crack eggshells?
  • Thread starter Thread starter molly_liz
    Crack
The discussion focuses on using a pendulum to crack eggshells for a science fair experiment. Calculating the force of the pendulum is challenging due to rapidly changing collision forces, and monitoring angular acceleration may not yield sufficient data. Instead, correlating impact energy could be a more effective approach. Alternatively, using a compression spring with a spike or marble could provide a more accurate measurement of force by calculating spring compression. Additionally, the non-uniformity of eggs in terms of shape, shell thickness, and brittleness could affect the experiment's results.
molly_liz
my friend and i are doing our science fair experiment on the strength of eggshells. we plan on using a pendulum to crack the eggs but do not know how to calculate the force of the pendulum, which we can then use to find the strength of the eggshell.
Calculating the force may prove very difficult because collision forces change rapidly with time. Theoretically, if you monitored the angular acceleration of the pendulum you might be able to calculate the contact force, however in practice I doubt you would be able to make enough measurements per second to see such a short collision. If you would like to do the pendulum, you may be more successful correlating the impact energy instead of force.
If you would still like to do the force study, you may have more luck with springs. You could mount a spike (or marble) on a compression spring and use a vice to push the egg into the spring. By measuring the compression of the spring you would be able to calculate the force (Provided you know the spring constant of the spring in question).
Also, you may want to consider the non uniformity of the eggs. Some eggs simply have different shapes, shell thicknesses and brittleness which if not controlled could cause problems with your results.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
