Using a weight function for inner product/normalization
  • Thread starter Thread starter kakarukeys
    Function Weight
kakarukeys
if we use weight function for inner product/normalization of wavefunctions, what will the momentum operator look like?
W(q,t)dq = dx
\int \psi'^*(q,t)\psi'(q,t) W(q,t)dq = \int \psi^*(x,t)\psi(x,t) dx
I may be wrong, but doesn't the weight function have something to do with the coordinate system you are in. If we look at a problem that has spherical symmetry our weight function is
W=r^2sin\theta.
We know the momentum operator in this case.
W(q,t)dq = dx
In a separable Hilbert space the choise of basis for the space is not unique.In your case of Hilbert space (the space of square modulus integrable functions) you can pick either of the 2 representations u like:momentum/coordinate.Let's say u have the more common coordinate representation.The simplest form for the Hamilton operator is in the rectangular coordinates,yet some systems may have coordinate symmetries,e.g.spherical,cylindrical,hyperboloidal,...The change of coordinates in the same representation automatically alters the other representation's operators and variables.
If u change the "x","p_x" will change as well,but the fundamental commutation relation is left invariant.
To conclude,my guess is that weighing functions are the Jacobian of the (usually orthogonal) coordinate transformation within the same representation,and their connection wrt to mometum operators is not immediate in the coordinate representation but is relevant in the momentum representation.
Thanks, by the time there were replies to my thread.
I already figured it out myself.
Yes weight function has something to do with coordinate transformation.
I only had one question not figured out, but this is mathematical
Given two equivalent descriptions of the physics related by a coordinate transformation, one of them has a weight function always > 0 in its inner product.
\int \psi'^*_A(q,t)\psi'_B(q,t) W(q,t)dq = \int \psi^*_A(q,t)\psi_B(q,t) dq
upper/lower limits are the same.
Is \psi'(q,t) = \frac{C}{\sqrt{W(q,t)}}\psi(q,t) the only possible transformation? (|C|^2 = 1)
C=exp(-if(q,t)) also works where f is any "good" function.
Seratend.
I meant besides this kind of manipulation
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
