Using Multiple Data Sets on One Graph in PSPICE: Changing X Variable
  • Thread starter Thread starter hitman012
    Pspice Variable
This discussion focuses on using PSPICE to plot Vce against Ic for various base currents (Ib) of a transistor while managing multiple data sets on one graph. The user successfully employed a DC Sweep simulation with a primary sweep on the collector resistor and a parametric sweep on the base resistor. However, they encountered a limitation when attempting to change the X variable to the collector current (Ic), receiving an error message indicating that only one X variable is allowed. The conversation suggests that an iterated sweep approach may be a viable solution to this issue.
  • Understanding of PSPICE simulation software
  • Familiarity with DC Sweep and parametric sweep techniques
  • Knowledge of transistor characteristics and parameters (Vce, Ic, Ib)
  • Basic experience with plotting data sets in simulation tools
  • Research how to perform iterated sweeps in PSPICE
  • Learn about advanced plotting techniques in PSPICE
  • Explore the use of parametric sweeps for multiple variables
  • Investigate troubleshooting common PSPICE error messages
Electronics engineers, students learning about transistor behavior, and anyone using PSPICE for circuit simulations and data visualization.
hitman012
Hi,
I'm running a simulation on PSPICE in which I am trying to plot Vce against Ic for various base currents of a transistor, and I therefore need to have multiple data sets on one graph. I've managed to do this by using the DC Sweep simulation with the primary sweep on the collector resistor and a parametric sweep on the base resistor.
The resulting graph does have a data set for each value of the base resistance, but I am unable to change the X variable to the collector current: it gives me a message saying "Only 1 X variable is allowed" or something like that.
Is there a way round this?
Thanks.
So, you are plotting Vce against Ic for a range of stepped Ib's? I really don't think you need to use variables to do this. You can just do a iterated sweep sort of thing.
Could you explain how to do this? I've only been using PSPICE for a week or two, so I'm quite new to some of these features.
Many thanks for your response.
27K
11K
  • · Replies 19 ·
