Can Op Amps be Used for Digital Circuits?
Op amps can be utilized in digital circuits by creating various logic gates through configurations like window comparators. In TTL logic, 0 volts represents a logical 0 and 5 volts a logical 1. While experimenting with op amps for digital applications, challenges may arise, particularly when integrating concepts like ternary logic. Understanding the limitations of op amps, especially when using single supply rails, is crucial for effective implementation. Resources like "The Art of Electronics" provide valuable insights into practical applications and operational requirements for op amps in digital circuits.
PhilosophyofPhysics
I had electronics last semester, and we went over some digital briefly at the end. I think we learned a bit about digital circuits using diodes and something about transitor-transitor logic?
Anyway, at the time I was wondering if there was a way to use Op Amps to create digital circuits.
In TTL, 0 volts = 0 and 5 volts = 1
You can easily achieve various gates with op amps, a combination of window comparators could work.
I remember after the semester ended I was attempting to create gates with op amps and I was getting some 2s in there. I might have then tried to see how it fit in with ternary instead of binary.
but it seems as if too much of my memory has decayed since then. I need to read up on this stuff again.
I'd recommend that you read the intro electronics book "The Art of Electronics" by Horowitz and Hill. In there, you will learn all kinds of practical things, like what it takes to run an opamp with a single supply rail like 5V. You cannot run just any old opamp between those rails and expect to get something useful.
cool my school has a copy
i'll check it out
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
