B UV timelapse of the Sun in 4K, 52 min = 1 second
  • B
  • Thread starter Thread starter Spinnor
    Sun The sun Uv
The UV timelapse of the Sun showcases stunning solar flares that appear to reverse direction, prompting questions about their behavior. Observers note that instead of falling back to the Sun's surface, the flares seem to change intensity, leading to speculation about whether this is an artifact of the time lapse. Some suggest that the plasma is influenced by magnetic field lines, which could explain the upward movement followed by a return flow. The discussion highlights the complexity of solar dynamics and the visual effects captured in the video. Understanding these phenomena can enhance our knowledge of solar activity and its implications.
Spinnor
Stunning and mesmerizing,
  • Wow
  • Love
Likes DennisN, Dragrath, sophiecentaur and 5 others
Astronomy news on Phys.org
Amazing video!
Why is it that the flares appear to reverse course exactly. See at the right side at 1 minute mark for an example. One would expect that the flare would fall back to surface of the sun, as if you sprayed water with a hose on an angle.
Is this an artifact of the time lapse, what one sees is the change in intensity of the flare over time as opposed to some matter being ejected?
I'm guessing that the plasma is following the magnetic field lines. Perhaps it is ejected, flies upwards until gravity stops it, then flows back down the field lines as it falls back.
Likes Nick-stg
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
