V, I, R in series circuit confusion
The discussion revolves around the results of a circuit experiment focused on the relationship between wire length, resistance, voltage, and current in a series circuit. Participants explore the implications of their experimental data and the underlying principles of electrical resistance.
  • Experimental/applied
  • One participant expresses uncertainty about whether the voltage should increase with increased wire length, despite expecting resistance to increase and current to decrease.
  • Another participant suggests that voltage should increase slightly as resistance increases, but asserts that current should decrease.
  • A participant shares preliminary data showing that voltage increased slightly while current decreased as wire length increased, but questions the extent of these changes.
  • Concerns are raised about the battery potentially being depleted, which could affect the measurements and the relationship between voltage and current.
  • Participants discuss the possibility of contact resistance affecting the measurements and the reliability of the data.
  • Suggestions are made to improve the experiment, including adding a resistor in series and collecting more data points to better analyze the relationship between resistance and wire length.
  • There is a discussion about whether resistance is proportional to wire length, with some participants agreeing that it should be, while also acknowledging potential complications from contact resistance.
Participants express differing views on the expected behavior of voltage and current in relation to resistance changes. There is no consensus on the reliability of the experimental results or the reasons behind the observed data trends.
Participants note potential limitations in the experiment, including the condition of the battery, contact resistance, and the need for more data points to clarify the relationship between resistance and wire length.
JoeN
I'm doing coursework on a circuit experiment we performed in class. I'm pretty sure the results are wrong or flawed, but we were testing the effect of increasing the length of wire on the resistance. I had a voltmeter about the wire, a cell, an ammeter, and completed the circuit by attaching the croc. clips to the wire...
Of course, the resistance should increase and the current decrease, but should the voltage increase, as it did in my experiment? And should it increase enough to also make the current increase despite the higher resistance? I know that more work is needed to push the charge through the wire if you increase its length, so in theory the wire's potential difference should increase (?) but I'm not so sure the current should increase... This didn't occur in the preliminary data I carried out either.
I'm not sure about the voltage of the cell. Well, I know it was 1.5V but it had been used enough to make that irrelevant.
Oops, wrong forum. Sorry about that
It should increase slightly, yes.
No. Current should decrease.
Can you post your measurements? These could help. I can think of several reasons for your measurements, but I might be able to eliminate some of them if I saw your data.
Now, why should the voltage increase as you increase the resistance? Imagine that you have 2 resistors of 10 Ohm each in series with 3V applied across. You have 20 Ohms of total resistance, giving you current of 0.15A. And that gives you 1.5V across each resistor. Now say, I increase resistance of one of these to 20 Ohm. That means total is now 30 Ohm, current drops to 0.1A, and the 20 Ohm resistor has 2V across it now.
Wire you are measuring across isn't the only thing with resistance. There are other wires and battery's own resistance. So when you increase resistance of the wire, more of the battery's applied voltage is dropped across the wire. Hence, higher voltage measurement. But the current should only decrease. Unless, something else is going on.
My preliminary data:
length of wire V A1 A2 mean ohms
10 0.28 1.20 1.25 1.23 0.23
20 0.24 1.21 1.22 1.21 0.20
30 0.32 1.10 1.16 1.13 0.28
40 0.30 1.11 1.13 1.12 0.27
50 0.39 0.98 0.97 0.98 0.40
This experiment followed my expectations: V increased slightly, A decreased, R increased (although I think the R and A should have increased and decreased a lot more?). And thanks for that explanation.
L.O.W V A1 A2 mean ohms
10 0.06 0.64 0.68 0.66 0.09
20 0.08 0.62 0.65 0.64 0.13
30 0.10 0.70 0.72 0.71 0.14
40 0.12 0.72 0.71 0.72 0.17
50 0.14 0.77 0.75 0.76 0.18
And this is where it messes up. I performed both experiments in the same way, so my initial conclusion was a mistake in the circuit or faulty equipment. Is there another conclusion?
Sorry for the late reply!
Shouldn't your voltage equal the applied voltage from your cell? Or are you not able to develop voltage very well across a conductor?
true, you can't get more voltage out than what you put into a passive circuit like that
Dave
Both sets look very strange.
First of all, it looks like the battery might be dying. That alone could explain the increases in current. If you give a dying battery a bit of time, ti recovers a bit. So the internal resistance can decrease a bit. That could explain your data.
Second part, I don't think your contacts were very good. You simply shouldn't be getting that kind of resistance dependence on length. However, if there was significant additional resistance on clips, it fits.
There are two things you can do to significantly improve this experiment.
1) Put a 5-10 ohm resistor in series with the wire. This will reduce the current through the whole thing, and tax the battery a lot less.
2) Get more data points with different lengths. The range of 10-50 (mm?) is fine. Then plot all these points resistance vs length. Try to fit a curve that looks like R = k*L + R0 through these points for some constants k and R[/sub]0/sub]. Assume that this R0 is due to bad contacts. This way, you can predict the "real" dependence of resistance on length via the remaining terms, R = k*L. Alternatively, you could just subtract off this R0 from your data at this point.
I'm not in a position to perform the experiments again, unfortunately, I just have to evaluate the data.
1) Battery dying is likely. They have probably been used many times before I did the experiment. So a dying battery can eventually recover some voltage and decrease in resistance for a higher current?
2) "You simply shouldn't be getting that kind of resistance dependence on length" - you mean the resistance is too great a change, or too small a change? Is the resistance not proportional to the length of the wire?
Yes, that's what bothering me about resistance measurements. There could be any number of reasons for this, but I suspect contact resistance. In which case, you have a somewhat noisy bias to your resistance measurement.
Linear regression might still give you a reasonable fit. Though, more data points would help a lot.
Do you by any chance know the material and diameter of the wire? And the lengths, are they in mm? It'd be easy enough to compare results to expected value if these things are known.
  • · Replies 23 ·
  • · Replies 36 ·
  • · Replies 105 ·
13K
