Calculating Velocity of Center of Mass for Two Particles
To calculate the velocity of the center of mass for two particles, the formula Vcm = (m1v1 + m2v2) / (m1 + m2) is used. For a 5.3 kg particle moving east at 10 m/s and a 19 kg particle moving west at 10 m/s, the correct calculation must account for the direction of motion, assigning a negative sign to the westward velocity. The initial calculation incorrectly treated both velocities as positive, leading to an incorrect result. The correct approach reveals that the center of mass velocity is negative, indicating it moves westward. Understanding the sign convention for direction is crucial in these calculations.
mikefitz
If a particle of mass 5.3 kg is moving east at 10 m/s and a particle of mass 19 kg is moving west at 10 m/s, what is the velocity of the center of mass of the pair?
This one should be simple, here is my work:
(-5.3kg*10m/s + 19kg * 10m/s) / -5.3 + 19
= 10m/s
This is wrong according to my book, why isn't this velocity of the center of mass correct ? Thanks again for all the help tonight everyone.
A sign problem perhaps?
I thought since the 5.3kg particle was moving east it would have a different sign (-). In any case, the answer is still the same with a positive sign...
The velocity direction gives you a (-) for the velocity. The mass is always positive.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
