Which Formula Correctly Represents Velocity: V=v0 + 2at or V=v0 + at?
  • Thread starter Thread starter r3dxP
The discussion centers on the correct formula for calculating velocity, debating between V = v0 + 2at and V = v0 + at. It emphasizes that acceleration multiplied by time equals velocity, suggesting V = v0 + at is the correct representation. The conversation also touches on the integration of constant acceleration and references Galilei's formula, v² = v0² + 2ax, which is applicable for constant acceleration. The confusion stems from mixing different equations related to motion. Understanding these formulas is crucial for accurate calculations in physics.
r3dxP
which one is correct?
V=v0 + 2at ? or V=v0 + at ?
where v0 is initial and a is acceleration and t is time.
V=v0 +at
The acceleration part should be common sense. Acceleration * time = velocity.
**** i did all my questions wrong .. FUKFUKFUKUFKUFKUFK
You're mixing the simple time integration of constant acceleration with Galilei's formula
v^{2}=v_{0}^{2}+2 a x
also valid for constant acceleration along the Ox axis.
Daniel.
