Vacuum permittivty with alternative Standard-Unit for meters
  • Context: High School
  • Thread starter Thread starter GoodQuestion
    Si unit Vacuum
GoodQuestion
TL;DR
Value of Permettivity when 1m would be 1,10m
I was wondering: what would be the value of Vacuum Permettivity in the case 1 meter (say 1m") would be defined as the distance we nowadays see as 1,10 meters.
At first this looks easy: ##\varepsilon0 = 8.8541878128 \cdot 10{^{12}}## F / m with normal meters
so ##\varepsilon0" = \varepsilon0 \cdot 1.1##
##\varepsilon0" = 9.739660659408 \cdot 10{^{12}}## F / m" with converted meters.
However, when I look at Farads, this is defined as $$\frac{s^4 \cdot A^2}{m^2 \cdot kg}$$ so Farads should be converted too.
And Amperes are defined as:
"The ampere is that constant current which, if maintained in two straight parallel conductors of infinite length, of negligible circular cross-section, and placed one metre apart in vacuum, would produce between these conductors a force equal to ##2 \cdot 10^{−7}## Newtons per metre of length."
which also involves meters, and Newtons, which are defined as $$\frac{kg \cdot m}{s^2}$$
this all makes it too tough for me.
So, in short, my question is: is the calculated version of E0" correct?
on Phys.org
"The ampere is that constant current which, if maintained in two straight parallel conductors of infinite length, of negligible circular cross-section, and placed one metre apart in vacuum, would produce between these conductors a force equal to 2⋅10−7 Newtons per metre of length."
That is the old definition. The modern definition is: "The ampere, symbol A, is the SI unit of electric current. It is defined by taking the fixed numerical value of the elementary charge e to be ##1.602176634×10^{−19}## when expressed in the unit C, which is equal to A s, where the second is defined in terms of ##∆ν_{Cs}##."
see: https://www.bipm.org/utils/common/pdf/si-brochure/SI-Brochure-9-EN.pdf
Under the current definitions of the SI the meter is defined as: "The metre, symbol m, is the SI unit of length. It is defined by taking the fixed numerical value of the speed of light in vacuum c to be 299792458 when expressed in the unit m/s, where the second is defined in terms of ##∆ν_{Cs}##."
So, if 1 METRE = 1.1 metre then c = 299792458 metre/second = 272538598 METRE/second
Then, since in the current SI we have $$\epsilon_0=\frac{e^2}{4 \pi \alpha \hbar c}$$ Thus, keeping all other SI defining constants the same and keeping physics the same, we simply have a reduction in the numerical value of c by a factor of 1.1 and thus an increase in the numerical value of ##\epsilon_0## by a factor of 1.1
Yes, but you shouldn't write it in units of F/m since you have changed the units.
Shouldn't ##\hbar## change also, because there's a meter in there as well?
Assuming the value of KG en second stays the same, shouldn't this lead to ##\varepsilon0##" becomes ##\varepsilon0 \cdot 1,1{^3}## ?
It is not necessary, but you certainly could do that if you wish.
  • · Replies 58 ·
11K
  • · Replies 101 ·
13K
  • · Replies 29 ·
  • · Replies 0 ·
