Value of a measuring rod in an expanding universe?
rasp
I have a question, but I'm a neophyte so please correct my premise if it is wrong. If it is true that in an expanding universe the space between any 2 points increases than wouldn't it be true that the space between the end points of a measuring rod (e.g. a light year, or more fundamentally a meter) would increase in like proportion to the objects it is measuring (e.g. 2 stars). Therefore wouldn't the distance between 2 stars measured today (using today's rod) be the same as the distance between those same 2 stars measured in the past(using the past rod). If that were true, wouldn't it appear (disregarding doppler effects and other such phenomena) that the universe was static?
No, only the space between comoving (coming with the expansion) points increases.
A meterstick is a bound system, so at least one (an possibly both) ends of it will not be comoving.
You are right in that changing all distances by a factor of two would be a scale change and thus unobservable, but that's not what the expanding space idea is about - though the popular version of "expanding space" isn't very clear, and confusion like yours is common.
You might also look at the following papers:
"Expanding space: the root of all evil?" http://arxiv.org/abs/0707.0380
"Expanding confusion" http://arxiv.org/abs/astro-ph/0310808
The first talks about some criticism of the expanding space idea, but explains how to interpet the paradigm correctly to avoid confusion, so it might be especially helpful. The second is a bit more advanced, I think, but relevant.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
