What are the effects of fluctuating dipoles in Van der Waals interactions?
  • Thread starter Thread starter hasan_researc
    Dipoles Molecules
A fluctuating dipole refers to a dipole that changes its orientation and strength over time, akin to a harmonic oscillator. Dipoles can form within a molecule due to the coupling of electrons with fluctuating electromagnetic fields present in the quantum vacuum, even in the absence of nearby dipoles. This interaction causes the electrons to deviate from their normal orbitals, resulting in a fluctuating dipole moment. The fluctuating dipole then generates an electric field that can induce dipoles in nearby neutral atoms or molecules, with the induced dipole's strength depending on the relative positions of the atoms. The discussion also clarifies that while the dipole moment can be expressed as q times alpha, it inherently includes time dependence due to the nature of the forces acting on the charges.
hasan_researc
My lecturer writes the following in his lecture notes:
“Van der Waal’s : Fluctuating dipole of molecules induces dipoles in molecules or other-
wise neutral atoms (eg noble gases)”
Does a fluctuating dipole refer to a dipole that is changing its orientation in space?
How causes a dipole to be formed within a molecule, provided that there are no nearby fluctuating dipoles?
Finally, how can the fluctuating dipole of one molecule induces dipoles in molecules or other-
wise neutral atoms?
Tahns in advance for any help!
The dipole can be thought of as being something akin to
\mathbf{p} = \alpha (t) \hat{z}
where
-d \leq \alpha (t) \leq d
In other words, the fluctuating dipole is like a harmonic oscillator where the positive nucleus lies at the equilibrium position and the electron is moving back and forth in space. In the above I just restricted it along a single dimension for simplicity though. So yes, the dipole is changing its orientation and its strength.
The original paper by London did not make any assumptions on how these dipoles are fluctuating. In quantum mechanics, the harmonic oscillator has a non-zero energy ground state and is always oscillating. London assumed that the electrons in the polarizable atoms or molecules behave like the quantum oscillator. Thus, the basic assumption assumes that the dipoles will always fluctuate but he did not give a more basic reason.
One reason for this can be found by the fact that the quantum vacuum contains fluctuating electromagnetic fields even in the ground state. If we use quantum field theory to describe the electromagnetic fields, we find that in the ground state, called the vacuum where there are no photons, the expectation (mean) value of the electric and magnetic fields is zero. However, the fields do fluctuate about the zero point because they are also described as harmonic oscillators. The fluctuating electric and magnetic fields couple with the electrons in an atom or molecule. This coupling causes the fluctuations that give rise to the dipole moment that London assumed in his paper.
So in short, one way to think about it is that the electrons couple with the vacuum fields which cause them to fluctuate from their normal orbitals and this gives rise to a fluctuating dipole moment.
Now this new fluctuating dipole moment gives rise to its own electric field. This electric field will act on a nearby atom or molecule and induce a charge separation between the nucleus and orbiting electron and thus cause another dipole moment (this is the same mechanism as how the vacuum fields create the original fluctuating dipole moment).
The difference with the fluctuating dipole moment that is induced by the neighboring atom versus the vacuum induced moment is that the vacuum induced moment is independent (more or less) of the position of the atom in space. However, the position of the two atoms relative to each other affects the dipole moment that one atom's dipole induces in the other atom. The fact that the induced dipole moment is dependent upon position means that the energy of the system is position dependent and thus there is a force (since force is the gradient of the potential of the system).
Thanks! Your discussion is very clear.
I am wondering if the diople moment should equal q times alpha.
Eh, depends. The dipole moment is always time-varying. However, a lot of times we work in the frequency domain which assumes a exp(-i \omega t) time dependence. So often when you are given a dipole moment described as \alpha q, they really mean \alpha q exp(-i \omega t). So we can certainly think of the dipole moment as some q\alpha but there still needs to be an inherent time dependence somewhere since the charges are being acted upon by a time-varying force. As for \alpha versus \alpha q, it doesn't matter. I'm just using \alpha as a constant here in which we can absorb the charge. We generally talk about the molecules or atoms have a polarizability of \alpha as opposed to being a direct dipole of q d where d is the distance of separation between two charges of strength q.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
