Why Does the Van der Waals Equation Square the Number of Moles?
  • Thread starter Thread starter unscientific
    Gas
The Van der Waals equation incorporates a correction for pressure due to molecular attraction, represented by the term n²a/V², where 'n' is the number of moles. This squared relationship arises because the inward cohesive forces affecting pressure are proportional to the interactions between molecules in the outer layers of gas. The number of molecules in these layers is related to the total number of molecules divided by the volume, leading to the conclusion that the force reducing pressure is proportional to (n/V)². The assumption that the number of molecules in adjacent layers is equal simplifies the derivation of the pressure correction term. Thus, the equation accurately reflects the behavior of real gases by accounting for molecular cohesion.
unscientific
http://en.wikipedia.org/wiki/Van_der_Waals_equation
I understand the first equation where a is the measure of attraction between particles, and b is the volume of one particle.
The second equation includes 'n', the number of moles of gas.
1) v-nb is simply the volume occupied by the gas minus the volume of the particles (usually one atomic diameter)
why is the must the n be squared; n2a/V2 and not simply n?
My general idea is that n is proportional to the volume, so whenever there is a V2 or even V3 n must sort of 'follow' the power?
bumpp
bumpp~
I don't know why you have been unable to look this up for yourself, but since no one else is prepared to provide an answer and that is what PF is for:
The correction term to the pressure component is due to molecular cohesion (forces of attraction between molecules). The effect is similar to surface tension and is derived like this.
Molecules within the body of the gas are surrounded by other molecules and so (on average) experience no net force in any direction from the attractive forces between the molecules.
Molecules in the outer layer have molecules on the gas side but none on the container side so experience a net force inward towards the body of the gas.
But the pressure exerted by the gas on the container is made up by summing all the outward forces from the molecules. These are reduced by the net inward cohesive forces.
To derive a mathematical expression note that the inward forces must be proportional to
1) ζ1 - The number of molecules in the outer layer
2) ζ2 - The number of molecules in the layer immediately next to the outer layer
Since both layers are very thin Van Der Waals made the assumption that
ζ1 = ζ2 = ζ
Now the number of molecules in any given space (part of the volume) is proportional to the total number of molecules divided by the volume
So the force responsible for the reduction of pressure \propto ζ1ζ1 \propto ζ2
Since ζ \propto n/V, ζ2 \propto (n/V)2
Introducing the constant of proportionality, a, we arrive at the pressure correction term, which we must add back to the pressure to get the true pressure.
\left( {P + \frac{{a{n^2}}}{{{V^2}}}} \right)
go well
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
