Variable amplitude for shaker table
To achieve variable amplitude on a shaker table, modifications to the design are necessary since the current setup only allows for fixed amplitude. Suggestions include either adjusting the mass of the spinning component or changing the distance between the mass and the motor shaft. This approach will enable better control over the amplitude for testing various distances. The ability to modulate these factors is crucial for achieving the desired range of amplitudes. Implementing these changes can enhance the functionality of the shaker table significantly.
ftrflyr
Hi All,
I built this shaker table: and I am now trying to change the amplitude so that it is no longer fixed but instead variable. The frequency I can change but the amplitude is fixed given this design.
Does anyone have any suggestions on how to be able to change the amplitude so I can test for a range distances?
thanks!
ftrflyr said:
Hi All,
thanks!
Since the amplitude of the vibration is crudely controlled by the spinning mass, you need to either modulate the mass or the distance the mass is separated from the motor shaft.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
