Varying with respect to vierbein
  • Thread starter Thread starter pleasehelpmeno
pleasehelpmeno
Hi
Can anyone explain how to vary an action e.g \int d^4 x e [\frac{1}{2}\partial_{\mu}\partial^{\mu} \phi + i\bar{\psi}\bar{\gamma}^{\mu}D_{\mu}\psi] w.r.t the vierbein?
Where e here is the determinant of the vierbein, and D_{\mu} is = to \partial_\mu + \frac{1}{4}\gamma_{\alpha \beta} \omega_{\mu}^{\alpha \beta}
For the first term, I think you actually mean ##\partial_\mu \phi \partial^\mu \phi = g^{\mu\nu} \partial_\mu \phi \partial_\nu \phi##. So remember that the metric is made of vierbeins.
For the second term, are you assuming the spin connection is a function of the vierbein, or is it an independent field? If the spin connection depends on the vierbein, then write down the expression for it in terms of the vierbein, and vary that.
For the determinant, same technique applies as for varying the metric determinant.
I know that the answer should be T^{\mu \nu} = i/2 [\bar{\psi}\bar{\gamma}(\mu D_\nu)\psi - \bar{\psi}D(\mu \bar{\gamma}_\nu)\psi, but i just don't see why
I don't have the time to do the calculation, but you should check Van Proeyen's book on SUGRA. He treats in great detail these kind of calculations. Also, you didn't answer Ben's question: do you treat the spin connection as dependent field? The different treatments (first, second, one and a half order) can be confusing.
Thread 'Dirac's integral for the energy-momentum of the gravitational field'
See Dirac's brief treatment of the energy-momentum pseudo-tensor in the attached picture. Dirac is presumably integrating eq. (31.2) over the 4D "hypercylinder" defined by ##T_1 \le x^0 \le T_2## and ##\mathbf{|x|} \le R##, where ##R## is sufficiently large to include all the matter-energy fields in the system. Then \begin{align} 0 &= \int_V \left[ ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g}\, \right]_{,\nu} d^4 x = \int_{\partial V} ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g} \, dS_\nu \nonumber\\ &= \left(...
I started reading a National Geographic article related to the Big Bang. It starts these statements: Gazing up at the stars at night, it’s easy to imagine that space goes on forever. But cosmologists know that the universe actually has limits. First, their best models indicate that space and time had a beginning, a subatomic point called a singularity. This point of intense heat and density rapidly ballooned outward. My first reaction was that this is a layman's approximation to...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
