Solving Vector Division: Breaking Down the "12 Left" Answer
  • Thread starter Thread starter Ecterine
    Division Vector
The discussion centers around a vector division problem where the answer is stated as "12 left," which confuses participants. The explanation provided indicates that the velocity of one vehicle (the Buick) is perceived by another (the Audi) as moving towards it at 12 units to the left. Participants express frustration over the unconventional notation "b/a," which seems to imply the velocity of b in relation to a, rather than standard vector division. The consensus is that the notation is poorly chosen and may lead to misunderstandings in the course. Overall, seeking clarification from the teacher is recommended to navigate the confusion.
Ecterine
The question is: Vector b/a=_____
I guessed a few times (losing a point each time it was wrong) and finally got the answer.
The answer is: 12 left
The site (it's online homework) then gave this explanation:
"To the driver of the Audi, the Buick appears to be moving to the left and approaching the Audi at 12 . Recall that if you are driving a car, street signs seem to be coming toward you at the same speed that you are moving with respect to the earth. Notice that "toward you" is opposite to the direction of your motion with respect to the earth."
I'm so confused, this is basically the first homework assignment and I'm already lost. All I can find on google is "you don't divide vectors." The book doesn't have an example, and my teacher didn't go over this.
Why is the answer "12 left""? How do you figure that out?
I think the question was asked badly... it seems the notation b/a was supposed to mean the velocity of b with respect to a or the velocity of b as seen by a... ie: the velocity of b, in a's frame of reference...
you're right, you can't divide vectors... just seems like poor notation used in the question.
Thank you... I have a feeling that this class isn't going to go well for me. :/
I agree with learningphysics; b/a is not standard notation; I've never seen it used before.
I recommend showing this problem to your teacher and asking about this notation.
You'll be fine. Just keep doing the work, and everything will be cool.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
