Vector components problem determinings final kinetic energy
The discussion centers on solving a physics problem involving vector components to determine final kinetic energy. The user attempts to calculate final velocities using the equation vxf^2 = vxi^2 + 2aX, first determining acceleration from force vectors divided by mass. They encounter issues due to one negative acceleration, leading to confusion in calculating the final velocity. The user then shifts to using total vectors and recalculates various components, ultimately arriving at a final kinetic energy value that they believe is incorrect. Assistance is requested to clarify the calculations and ensure the correct application of physics principles.
synergix
question 2
http://web.viu.ca/hearnd/Courses/Phys121/F02Test2/Page%201.htm"
I have been trying to do question 2 on the practice test but I am stuck.
I was trying to calculate the final velocities along each vector by using the equation
vxf^2=vxi^2+2aX
first i determined the acceleration by dividing each of the force vectors by the mass of the object
but since one of the accelerations was negative I could not calculate the final velocity of that vector
so now I am trying with the total vectors for
sqrt(4^2 +0 +0)
because only one component out of three has any initial velocity
so vi=4m/s
F=sqrt(4^2+(-3)^2+2^2)=5.385N
so
a= 2.69258 m/s
d=sqrt(16^2+4^2+8^2)= 18.3303
v=sqrt(4+2(2.69258)(18.3303))
vf=10.13
Ek=106.09
which is wrong
any help would be appreciated
Work done = F.r = Change in KE.
Thanks
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
