Vector field dot product integration
Unart
Calculate F=∇V, where V(x,y,z)= xye^z, and computer ∫F"dot"ds, where
A)C is any curve from (1,1,0) to (3,e-1)
B)C is a the boundary of the square 0≤x≤1, 0≤y≤1... oriented counterclockwise.
∫F"dot"ds= ∫F(c(t)"dot"c'(t)
So my question is how do I pick a curve from the two dots? And, how is it different from a square?
Doesn't the suggestion to use "any curve" suggest that it doesn't matter what curve you use? Is that the case in this problem? What do you know about independence of path and potential functions etc.?
I know that the V(Q)-V(P) should equal the integral for F dot ds along any path. And that's about it. How to approach it I'm confused...
Do I just, do the subtraction of products of the function? Or, do I have to invent a curve too...
How would I approach the square when the z variable isn't mentioned.
This is my first time doing this.
That is an obvious typo. Does it mean (3,e,-1) or what?
Oriented counterclockwise when viewed from where? Above or below the xy plane? And I suppose z = 0??
[If the integral is independent of path] And that's about it. How to approach it I'm confused...
First you have to check whether your integral is independent of path and the vector field has a potential function. What is the test for that? And if it does have a potential function ##\Phi## then, yes, the value of the integral is the difference of ##\Phi## at the end points.
It does... the function is continuous...
Oriented counterclockwise when viewed from where? Above or below the xy plane? And I suppose z = 0??First you have to check whether your integral is independent of path and the vector field has a potential function. What is the test for that? And if it does have a potential function ##\Phi## then, yes, the value of the integral is the difference of ##\Phi## at the end points.
Just because a vector field is continuous doesn't mean it has a potential function. There are theorems about gradients and curls and potential functions. What do they tell you for this problem?
[Edit, added]: Have you had the "fundamental theorem of calculus for line integrals"?$$
\int_P^Q \nabla \Phi \cdot d\vec R=\, \, ?$$
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
