Vector - points in same direction
The discussion revolves around determining which options point in the same direction as the vector V = (-sqrt2, sqrt3, sqrt5). Participants highlight the importance of understanding that any positive scalar multiple of a vector will point in the same direction. The user expresses uncertainty about how to represent vectors and square roots in the forum format. The community encourages a focus on vector properties rather than providing direct answers, emphasizing the need for clarity in mathematical expressions. Overall, the conversation aims to guide the user toward understanding vector directionality and proper notation.
marionca57
I don't know how to make the vector arrow on top of the letter so I just underlined the vectors. Also I don't know how to make the square root symbol so I just type sqrt for it.
Which points in the same direction as V = (-sqrt2, sqrt3, sqrt5)
a) 1/10 V
b) sqrt10/10 V
c) sqrt10 V
d) sqrt 10 V
I am not sure where to start other than calulating the sqrt of 2,3, and 5. My best guess would be c but I need to know why if that is correct or some help figuring it out.
Please help,
Thanks,
Marion
Welcome to PF!
Hi Marion! Welcome to PF! :smile:
(have a square-root: √ :smile:)
On this forum, type vectors in bold. :wink:
a) 1/10 V
b) sqrt10/10 V
c) sqrt10 V
d) sqrt 10 V
(c and d look the same :confused:)
As you probably know, on this forum we don't tell you the answer, we just try to nudge you in the right direction. :wink:
What tests do you know for two vectors to be pointing in the same direction? :smile:
It is a good idea to make carefull use of parentheses so that there is no
ambiguity as to the meaning of an expression.
Consider that for positive constants k, and vectors v, k v is in the same direction of v.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
