Vector Question (Velocity & Acceleration)
The discussion revolves around calculating the vector position and velocity of a particle with given acceleration and initial velocity. The particle has an acceleration of 3.00j m/s² and an initial velocity of 5.00i m/s. The calculated velocity at any time t is v = (5.00i + 6.00j) m/s, but confusion arises regarding the need to calculate speed using the Pythagorean theorem, which yields a speed of 7.81 m/s. The clarification provided states that speed is simply the magnitude of the velocity vector, and the angle of the velocity vector from the i-axis is 50.2 degrees. Understanding these relationships is crucial for correctly interpreting the results.
specwarop
Gday,
Just need a bit of help with this one. I have done the calcs and gotten the end answer as per the answers at the back of the book, but I am not quite understanding it.
A particle initially located at the origin has an acceleration of a=3.00j m/s^2 and an initial velocity of Vi=5.00i m/s. Find (a) the vector position and velocity at any time t and (b) the coordinates and speed of the particle at t=2.00sec.
Okay well i have worked it out and gotten this for the velocity, v = (5.00i + 6.00j)m/s. This is not the end answer. I then had to use Pythagoras and solve the above to get v= 7.81m.s. That is where I'm confused, why did I have to do that, and how is it related?
Any help appreciated
Speed is the magnitude of the velocity. Simple as that really.
Angle from i = atan(6.00/5.00)=50.2deg
