Vectors. Determine the eqn. of plane M?
  • Thread starter Thread starter bob29
    Plane Vectors
To determine the equation of plane M containing vectors a and b and point P(2,1,-1), the normal vector can be found using the cross product of the vectors a and b. The equation of the plane can then be expressed as a linear equation based on the normal vector and the coordinates of point P. The derived equation is -x + y + z = -2. Understanding the relationship between vectors, lines, and planes is crucial for solving such problems. The solution highlights the importance of recognizing the role of normal vectors in defining plane equations.
bob29
Question is:
Given the vectors a= i - j + 2k and b= 2i + 3j - k, determine the equation of the plane M that contains the vectors a and b and the point P(2,1,-1).
x = xo + at
y = yo + bt
z = zo + ct
PoP = tv ---> (x-xo)i + (y-yo)j + (z-zo)k = t(ai + bj + ck)
where Po (xo, yo, zo)
P(x, y, z)
pt= (2,1,-1)
direction: v = ab= i + 4j - 3k
equation of line:
x=xo + at --> x= 2 + t
y=yo + bt --> y= 1 + 4t
z=zo + ct --> z= -1 - 3t
and that's where I get stuck, and I don't know how to continue.
The answer is -x + y + z = -2.
I am unsure how to get to that answer.
Got the answer nevermind.
You have a lot about vectors and lines there, but nothing about planes. You need to know two fundamental facts:
1) The plane with normal vector a\vec{i}+ b\vec{j}+ c\vec{k} and containing point (x_0, y_0, z_0) has equation a(x- x_0)+ b(y- y_0)+ c(z- z_0)= 0.
2) A normal vector to the plane containing vectors a\vec{i}+ b\vec{j}+ c\vec{k} and d\vec{i}+ e\vec{j}+ f\vec{k} is the cross product of the two vectors (bf- ce)\vec{i}- (cd- af)\vec{j}+ (ae- bd)\vec{j} which can be remembered by writing it (as a mnemonic) as if it were a determinant:
\left|\begin{array} {ccc}\vec{i} & \vec{j} & \vec{k} \\ a & b & c \\ d & e & f\end{array}\right|
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
