Vectors that form bases (linear algebra)
Niles
[SOLVED] Vectors that form bases (linear algebra)
I am given two vectors u and v, which are:
u = (1/2 , 1/2 , 1/2 , 1/2) and
v = (1/2 , 1/2 , -1/2 , -1/2).
I have to find an orthonormal basis for R^4 containing u and v.
The first thing that came to me was Gram-Schmidt - but then I saw that the dot-product between u and v is zero, so Gram-Schmidt is overkill.
I just need to find two other linearly independant vectors that has dot-product equal zero with respectively u and v. Is that even possible and how would I do that?
Okay, u and v are already orthogonal so you really just need to find two more vectors that are orthogonal to both u and v (and to each other). Let w= (a, b, c, d). Then u\cdot w is (1/2)a+ (1/2)b+ (1/2)c+ (1/2)d and you want that equal to 0. That, of course, is the same as a+ b+ c+ d= 0. v\cdot w is (1/2)a+ (1/2)b- (1/2)c- (1/2)d= 0 which is the same as a+ b- c- d= 0. Adding the two equation, you get 2a+ 2b= 0 or b= -a. With b= -a, the first equation becomes c+ d= 0 or c= -d. Choose a and d to be whatever you want and you will get a vector orthogonal to both u and v. You should be able to choose one value of a and d to get a vector orthogonal to u and v, then choose another value of a and d to get a vector that is orthogonal to u and v and also to your first vector.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
