Velocity/acceleration/time to stop
  • Thread starter Thread starter lauriecherie
The discussion revolves around calculating the time required to reduce a car's speed from 132 km/h to below 90 km/h using brakes that decelerate at 4.9 m/s². Initial calculations led to an incorrect estimate of 8.57 seconds due to a failure to convert speeds from km/h to m/s. After receiving guidance, the correct calculation yielded a time of approximately 2.38 seconds. The importance of unit conversion in physics problems is emphasized. Accurate calculations are crucial for determining stopping times effectively.
lauriecherie
The brakes on your car are capable of slowing down your car at a rate of 4.9 m/s^2.
If you are going 132 km/h and suddenly see a state trooper, what is the minimum time in which you can get your car under the 90 km/h speed limit?
v(t)= at + initial velocity
(final velocity^2) - (initial velocity^2) = 2*a*delta X (change in position)
I came out with 8.57 seconds. Is there some converting I maybe missed?
Hi Laurie, welcome to PF!
I don't know how you got 8.57. I got between 2 and 3s. Show your calc and we'll find your error.
Did you remember to convert the speeds to m/s ?
No, I didn't convert. Whoops. So let me work this out again. Thanks for the advice.
2.380952388 seconds. :!) Thanks soooo much for your help!
Most welcome!
