Velocity/displacement/time problem
  • Thread starter Thread starter xotash
A person throws a ball upwards from a balcony at an initial velocity of 30 m/s from a height of 15 m. The problem involves calculating the time it takes for the ball to hit the ground. The relevant kinematic equations, particularly the SUVAT equations, are suggested for solving the problem. It's important to define the coordinate system and correctly assign signs to the variables involved. The discussion emphasizes the need to clarify the initial conditions and apply the appropriate equations to find the solution.
xotash
1. Homework Statement
A person on an apartment balcony holds a ball over the balcony and throws it directly upwards with an initial velocity of 30 m/s [up]. The ball was thrown from 15 m above the ground. How long will it take for the ball to hit the ground?
The givens I have here so far I think is:
V1 = 30 m/s [up]
V2 = 0 m/s
∇d = 15 m
Why do you think v2=0?
You don't need this anyway.
Draw your y-axis and choose a location for the origin, and then write down the information you are given taking care with the signs.
Then you can just choose the most appropriate suvat equation.
