Velocity divided by Acceleration gives distance?
Velocity divided by acceleration does not yield distance, as the units do not align correctly. The discussion highlights a common confusion between the symbol 's' representing distance in kinematic equations and 's' as a unit of time in seconds. The correct relationship is that velocity multiplied by time equals distance, not divided by acceleration. Participants clarified that the initial misunderstanding stemmed from mixing units and symbols. Overall, the thread emphasizes the importance of correctly applying kinematic equations to avoid confusion in physics calculations.
Mongster
See I figured that since Velocity = m/s
Acceleration = m/s^2
If I have velocity divided by Acceleration
----> m/s ÷ m/s^2 = s
Relevant equations
Velocity --> s/t
Acceleration --> (v-u)/t
The attempt at a solution
My idea seems reasonable to me but somehow I couldn't apply this logic to related questions. Based on my understanding, velocity divided by acceleration gives distance as 's' but it don't seems applicable when I attempted questions with this approach.
Mongster said:
. Based on my understanding, velocity divided by acceleration gives distance as 's' .
No it doesn't. You're mixing symbols with units, s is short for seconds. eg velocity is metres per second (m/s)
In the kinematic equations (SUVAT) 's' is used to represent distance (which has units of metres)
s is distance in metres (m)
u is initial velocity in metres per second (m/s)
v is final velocity in metres per second (m/s)
a is acceleration in metres per second squared (m/s2)
t is time in seconds (s)
Oh wait... I see the mistake now oh my, hahaha! It is really stupid... *cringing*
But thanks a lot for the detailed explanation there, appreciate it really!
Cheers!
Relevant equations
Velocity --> s/t
That's only because the masses (m) canceled out. :rolleyes: o_O :confused:
Yes. s is correct. How long it takes to reach the velocity. "Long" being the "distance". It is something like a period vs frequency.
Don't confuse velocity x time = distance.
Ummmm... What? How long it takes to reach the velocity... from what starting point?
Mongster even admitted that they confused the s (distance) with the unit s (seconds.) The problem was already solved 7 years ago, no need to add to it.
-Dan
Likes Greg Bernhardt
