Velocity From Electric Potential
The discussion centers on understanding the energy distribution between two particles based on their mass ratio, specifically 2:1. The energy of particle 1 is calculated as 2/3 of the total energy, while particle 2's energy is 1/3, derived from the change in electric potential as the particles move apart. Participants clarify that these ratios can be explained through conservation of momentum and the relationship between kinetic energy and mass. The concept of ratios and proportions is emphasized as a fundamental mathematical principle relevant to the problem. Overall, the conversation effectively resolves the confusion regarding the energy distribution in the context of electric potential.
PurelyPhysical
http://imgur.com/UsKsaOn
Why is the answer in joules multiplied by 2/3 and 1/2? I can follow the rest of the problem.
[/B]
I get the same solution as my teacher if I use the constants 2/3 and 1/2. I just don't understand where they are coming from.
I would want to correct the information you have given by looking at the solved equation.
The ratio of distribution of engergy for particle 1 and particle 2 is 2:1
So the energy of particle 1 will be: 2/(2+1)= 2/3 times the total energy
Energy of particle 2: 1/(1+2)= 1/3 times the total energy.
This "total energy" is basically the change in the electric potential as the particles move from being 0.1m apart to 0.2m apart.
Likes PurelyPhysical
Thank you very much! This clears it up for me. It never occurred to me to look at ratios that way. Is there a name for what this particular concept is in math?
Ummm...not really. It is generally covered in the topic of ratios and proportions.
I will explain a bit more here for you to have a better understanding:
Suppose a line segment of length A units is to be divided into a ratio of x:y
Then the length of each unit can be calculated as:
Ax/(x+y)
Similarly, the length of the other part will be:
Ay/(x+y)
To check we can easily see that the sum of each of the part of the line segment should be equal to the total length of the line segment.
so
Ax/(x+y) + Ay(x+y)= A
Hope it helped! :biggrin:
The energy ratios can be calculated by invoking conservation of momentum.
The total momentum of the system starts out as 0 and ends as 0.
m_1 \vec {v_1} + m_2 \vec {v_2} = 0.
Placing the particles on a line and noting that they move in opposite directions, we can get rid of the vector notation.
m_1 v_1 - m_2 v_2 = 0. [Edit: I'm just using the magnitudes of the velocities in this equation. If you'd rather allow negative velocities to indicate direction, then use m_1 v_1 + m_2 v_2 = 0. That's arguably the better approach anyway.]
Substituting m_2 = 2m_1 you can calculate a simple relationship between v_1 and v_2 (you can do that for yourself :wink:).
Note that the energy for each particle is
E_1 = \frac{1}{2}m_1 v_1^2,
E_2 = \frac{1}{2}m_2 v_2^2,
And the total energy is,
E_T = E_1 + E_2,
if you make the appropriate substitutions, you'll find the energy ratios are 2/3 and 1/3 of the total.
Ax/(x+y)
Ay/(x+y)
so
This does help, thank you very much :D
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
