Velocity From Electric Potential
The discussion revolves around understanding the relationship between electric potential and the energy distribution of two particles in motion. The original poster expresses confusion regarding the constants 2/3 and 1/2 used in the problem, which relates to energy ratios derived from the change in electric potential as the particles move apart.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the derivation of energy ratios for two particles based on their mass distribution and the conservation of momentum. Questions arise about the mathematical concepts behind these ratios and their application in the context of the problem.
Some participants have provided insights into the ratios of energy distribution and the underlying principles of momentum conservation. There is an ongoing exploration of the mathematical concepts involved, with no explicit consensus reached on the final interpretation of the problem.
Participants are discussing the implications of the energy ratios in the context of homework constraints, focusing on the derivation rather than a complete solution. The original poster's understanding of the problem is still developing, and there is a mention of the need for clarity on the mathematical concepts involved.
PurelyPhysical
http://imgur.com/UsKsaOn
Why is the answer in joules multiplied by 2/3 and 1/2? I can follow the rest of the problem.
[/B]
I get the same solution as my teacher if I use the constants 2/3 and 1/2. I just don't understand where they are coming from.
I would want to correct the information you have given by looking at the solved equation.
The ratio of distribution of engergy for particle 1 and particle 2 is 2:1
So the energy of particle 1 will be: 2/(2+1)= 2/3 times the total energy
Energy of particle 2: 1/(1+2)= 1/3 times the total energy.
This "total energy" is basically the change in the electric potential as the particles move from being 0.1m apart to 0.2m apart.
Thank you very much! This clears it up for me. It never occurred to me to look at ratios that way. Is there a name for what this particular concept is in math?
Ummm...not really. It is generally covered in the topic of ratios and proportions.
I will explain a bit more here for you to have a better understanding:
Suppose a line segment of length A units is to be divided into a ratio of x:y
Then the length of each unit can be calculated as:
Ax/(x+y)
Similarly, the length of the other part will be:
Ay/(x+y)
To check we can easily see that the sum of each of the part of the line segment should be equal to the total length of the line segment.
so
Ax/(x+y) + Ay(x+y)= A
Hope it helped! :biggrin:
The energy ratios can be calculated by invoking conservation of momentum.
The total momentum of the system starts out as 0 and ends as 0.
[itex]m_1 \vec {v_1} + m_2 \vec {v_2} = 0.[/itex]
Placing the particles on a line and noting that they move in opposite directions, we can get rid of the vector notation.
[itex]m_1 v_1 - m_2 v_2 = 0.[/itex] [Edit: I'm just using the magnitudes of the velocities in this equation. If you'd rather allow negative velocities to indicate direction, then use [itex]m_1 v_1 + m_2 v_2 = 0.[/itex] That's arguably the better approach anyway.]
Substituting [itex]m_2 = 2m_1[/itex] you can calculate a simple relationship between [itex]v_1[/itex] and [itex]v_2[/itex] (you can do that for yourself :wink:).
Note that the energy for each particle is
[itex]E_1 = \frac{1}{2}m_1 v_1^2,[/itex]
[itex]E_2 = \frac{1}{2}m_2 v_2^2,[/itex]
And the total energy is,
[itex]E_T = E_1 + E_2,[/itex]
if you make the appropriate substitutions, you'll find the energy ratios are 2/3 and 1/3 of the total.
Ax/(x+y)
Ay/(x+y)
so
This does help, thank you very much :D
