Velocity of a bee moving along the curve of intersection of 2 surfaces
karokr94
Hi, I've attached the problem and the solution. I understand the solution except for one thing. I've circled the part I'm having problems with. How do I decide if the circled part should be
f2(x,y,z)=x2-y2-z or
f2(x,y,z)=z-x2+y2
I'm sure it has something to do with the fact that the problem statement states that the bee is moving in the increasing direction of z, but I just can't figure out how it translates into f2 being one or the other. Or are both answers acceptable?
Thanks in advance for the help!
Never mind, I figured it out.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
