Velocity of air moving past a duct.
  • Thread starter Thread starter Jbreezy
    Air Velocity
To determine the velocity of air moving through a duct supplying a hospital room, the volume of the room must be exchanged six times per hour. The calculations initially led to an implausibly high velocity of 334.8 m/s, prompting a reevaluation of the time conversion for air exchanges. The correct conversion indicates that each cycle takes 600 seconds, not 60. This adjustment significantly alters the calculations, suggesting a more reasonable velocity of approximately 3.34 m/s. Accurate time conversion is crucial for solving airflow problems effectively.
Jbreezy
A hospital room has dimensions 8m by 9m by 3.25m tall. A round duct of diameter 12cm is used to supply air to the room. If the air in the room is to be exchanged 6 times every hour, how fast must the air move through the duct?
OK, I want to use this equation
I'm using
A = area of duct
V = velocity of duct.
The lower case letters represent the room.
AV = av
We want V.
So we get V = (av)/(V)
Now looking that the equation I don't have given information for the velocity of the air in the room (v). So , v = L/T where L = length and T = time.
So putting this back in we get
V = aL / VT
aL is just volume so
V = Volume of room / VT
Now from the problem they give us the period is 6 cycles per hour.
So T = 1/f
Then , (1hr/6cycles) (360 seconds) = 60 seconds ( I question this conversion because my answer seems high.)
Plugging all the values in we get.
V = ( 8m x 9m x 3.25m) / (Pi(0.06)^2 )(60 seconds))
So I got V = 334.8 m/s this seems totally wrong. Because of how fast it is.
What did I do wrong? Maybe 3.34 m/s seems more reasonable.
Please help me find my error.
Thanks,
I'm using
A = area of duct
AV = av
We want V.
V = aL / VT
So T = 1/f
There are 3600 seconds in an hour. So each cycle would be 600 seconds, not 60.
AM
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
