Velocity Of An Object Accelerated By A Spring
  • Thread starter Thread starter fcv33
    Spring Velocity
The problem involves determining the velocity of an object released from a compressed spring with a force constant k and initial compression x. The energy conservation principle is applied, equating the potential energy stored in the spring (E = 0.5kx^2) to the kinetic energy of the object (E = 0.5mv^2). The derived velocity formula is v = ((k/m)^(1/2)) * x, indicating that the object's velocity at the moment it leaves the spring depends on the spring constant, mass, and initial compression. An alternative approach using force and integration also leads to the same velocity expression. Understanding these relationships is crucial for solving similar physics problems involving springs and motion.
fcv33
I'm pulling my hair out over this problem. A spring with a force constant of k is compressed x meters. An object of mass m is placed against the spring. The spring is then released. At what velocity is the object moving at the instant that is ceases to touch the spring?
E=0.5kx^2
I'm really unsure. All of my solutions don't seem realistic.
Using Energy:
E=0.5kx^2=Kinetic Energy=0.5mv^2.
solve for v=((k/m)^1/2)*x
where x is initial displacement of spring.
Using F
F=-kx x is negative therefore
F=kx=ma
a=dv/dx*dx/dt = dv/dx*v
vdv=(kxdx)/m integrate
0.5v^2=0.5k/m x^2
v=((k/m)^1/2)*x
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
