Velocity Question for a Car Accelerating Down a Road
The car travels 240 meters in 8 seconds, resulting in an average velocity of 30 m/s. Its initial velocity at the first point is 12 m/s, which is below the average. Since the car is uniformly accelerating, its velocity at the second point must be greater than 30 m/s. The discussion emphasizes the relationship between initial velocity, average velocity, and uniform acceleration. Understanding these concepts is crucial for determining the car's final velocity.
asdek
A car uniformly accelerates along a straight road, goes the distance between two points 240 m apart in 8 s. Its velocity as it passes the first point is 12 m/s. Find the acceleration of the car and its velocity as it passes the second point.
V=D/S
240/8=30.
asdek said:
Problem Statement: A car uniformly accelerates along a straight road, goes the distance between two points 240 m apart in 8 s. Its velocity as it passes the first point is 12 m/s. Find the acceleration of the car and its velocity as it passes the second point.
Relevant Equations: V=D/S
240/8=30.
You seem to have calculated the car's average velocity. Is its velocity as it passes the first point above or below that average?
I'm sorry I don't understand, its velocity as it passes the first point is 12m/s. I'm not sure how to find out its velocity as it passes the secont point.
I repeat:
jbriggs444 said:
I repeat:
Below?
asdek said:
Below?
Yes. 12 m/s is less than 30 m/s.
We are told that the acceleration is uniform. Given this, will the velocity at the second endpoint be greater or less than 30 m/s?
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 25 ·
  • · Replies 48 ·
9K
