Calculating Velocity and Time for a Falling Coin
  • Thread starter Thread starter fifaking7
    Rate Velocity
The discussion focuses on calculating the velocity and time for a falling coin using the equation s(t) = Vit + 1/2 at^2 + So, with acceleration a = -32 ft/s^2. The average velocity over the interval [1,3] is calculated as -64 ft/sec, while the instantaneous velocity at t = 3 seconds is -96 ft/sec. The time taken for the coin to hit the ground is determined to be approximately 7.071 seconds, with the velocity upon impact calculated to be -226.272 ft/sec. Clarifications on average speed versus average velocity are also provided, emphasizing the need for accurate distance measurements over time intervals.
fifaking7
s(t)= Vit + 1/2 a t^2 + So
a) find the average velocity on the interval [1,3]
b) find the instantaneous velocity when t= 3s.
c) how long does it take the coin to hit the ground?
d) find the velocity when the coin hits the ground
a= -32ft/(s^2)
S(t)=Vi(0)t + 1/2 (-32ft/s^2)t^2 +So
S(t)= 0 -16t^2 + 800
v(t) = -32t
a) V(3)-V(1)/(3-1)
V(3) = -32(3)=-96
V(1) = -32(1)= -32
-96-(-32)/2 = -64ft/sec is my final answer
b) v(3)= -32(3)
C)coin hits ground at s(t)= 0 S(t)= -16t^2 + 800
0= =16t^2 +800
-800= -16t^2
sqr50= t^2
7.071 seconds is when the coin hits the ground
D) V(t) =-32t
V(7.071)= -32(7.071)
v= -226.272 ft/sec
1) Yes the average velocity can be calculated by differentiating s(t)
∴ s(t^{'}) = -32t
The average velocity turns out to be (-96 + 32)/2 = -32
2) The instantaneous velocity when t=3 s is given by
Lim Δt→0 Δs/Δt = ds/dt
So -32t = -32 × 3 = -96
3) s(t^{'}) = -32t
∴ s(t) = \int -32t dt
= -16t^{2} + C
4) Velocity is zero as when t=0 ; -32t = -32 × 0 = 0
There seem to be other facts which you introduce later. From those I infer a coin is dropped from rest at time 0 and a height of 800ft.
a) V(3)-V(1)/(3-1)
No, that will give you the average of two specific speeds. That is not the same as the average speed over an interval. Average speed = change in distance / change in time.
Abhinav R's method and answer are wrong too.
How do I do it then if the methods are wrong?
a= -32ft/(s^2)
v(t) = -32t
a) V(3)-V(1)/(3-1)
V(3) = -32(3)=-96
V(1) = -32(1)= -32
b) v(3)= -32(3)
0= =16t^2 +800
-800= -16t^2
sqr50= t^2
D) V(t) =-32t
v= -226.272 ft/sec
Please state the complete problem as it was given to you.
As I said, Average speed = change in distance / change in time. Where was it at t=1? Where at t=3? How far did it travel between t=1 and t=3?
