Velocity/Time/displancement Question
  • Thread starter Thread starter Aicelle
Two cyclists are traveling towards each other from Vectorville and Scalartown, which are 20.0 km apart, at speeds of 20.0 km/h and 15.0 km/h, respectively. The problem involves determining their meeting point and the time taken to meet. The cyclists meet 11.4 km from Vectorville after approximately 34.2 minutes. The solution process involves setting up equations based on their speeds and the total distance between the two towns. The discussion highlights the importance of establishing relationships between the distances traveled by each cyclist to solve for the unknowns.
Aicelle
Question:Vectorville and Scalatown are 20.0km apart. A cyclist leaves Vectorville and heads for Scalartown at 20.0km/h. A second cyclist leaves Scalartown for Vectorville at exactly the same time at a speed of 15.0km/h.
a) Where will the two cyclists meet between the two towns?
b) How much time passes before they meet (in minutes)?
Answers(From the back of the textbook): a)11.4km from vectorville; b) 0.571h or 34.2 min
d= v/t --> t = d/v
*sigh* I've tried everything, used like 3 peices of lined paper to work this equation. I first deicided to use the formula d=v/t rearranged to t=d/v afterwards, since there is no acceleration in this question. Then I concluded that both cyclist have the same time since it says they started at the same time, but we don't know at what time they meet each other nor the displacement of either of them during that time. So we've got two unknowns, therefore I tried merging the two equations of motions. Cyclist 1: t = d/ 20m/s ; Cyclist 2: t= d/ 15 m/s ---> d2 = 15km/h (d1/ 20 m/s) [subbed in cyclist 1's equation for time]. Then I kept trying to solve this but with no avail ;( Please help~
Hi Aicelle, welcome to PF!
You're right so far, d_{2} = \frac{15 d_{1}}{20}. But you have one equation now, and two unknowns (d_{1} \textrm{ and }d_{2}). Can you think of another relationship between them? How do they relate to the total distance?
Welcome to PF!
Hi Aicelle! Welcome to PF! :wink:
Say they're going along the x-axis …
the first one starts at x = 0 and the second starts at x = 20 …
what equations do you get? :smile:
Hmmm...total distance= d2+d1...so I can change d1 into 20-d2?
wait... we can simplfy d2=15d1/20 to d2=3d1/4...
Edit:Omigosh i got it =D
Sub d2=3d1/4 into the 20=d1+d2 equation =DDD Thanks everyone!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
