PhysicsNewb
- 7
Hi, I had three problems to do that are multiple choice, here they are and my answer with them. Please tell me if some are wrong.
1. Spherical conductor of radius R carries char +Q, which statement(s) are correct?
I. Electric field outside the surface of the conductor is the same as the field outside a uniformly charged nonconducting sphere of same radius and charge
II. Electric field inside the surface of the conductor is the same as the field inside a uniformly charged nonconducting sphere of same radius and charge
III. Nonspherical Gaussian surface drawn within the conductor will have a ney electric flux through it
I said that only statement I. was correct.
2. Gauss's law could easily be used to solve for the electric field outside all of the following charge distributions except
A.) charged nonconducting sphere
B.) long straight line of charge
C.) long charged conducting cylinder
D.) charged nonconducting cube
E.) charged nonconducting plane
I chose B. was correct.
3. Uniformly charged nonconducting sphere of radius R, charge +Q, is centered at the origin of a cartesian plane. Field strength at Point P with coordinates (R,0) just outside the surface will double if:
I. Add a point charge +Q at the origin
II. Add a point charge -Q at point (2R, 0)
III. Add a uniformly charged nonconducting sphere with charge -Q and radius 1/2R with its center at the point (2R, O)
I chose I. only as the answer.
Are these right? If not, please help..
