Verifying Stokes Theorem on Paraboloid z=0.5(x^2+y^2)
HeheZz
Verify Stokes Theorem ∬(∇xF).N dA where surface S is the paraboloid z = 0.5(x^2 + y^2) bound by the plane z=2, Cis its boundary, and the vector field F = 3yi - xzj + yzk.
I had found (∇xF) = (z+x)i + (-z-3)k
r = [u, v, 0.5(u^2 + v^2)]
Therefore N= ru X rv = -ui -uj +k
Therefore (∇xF).N = [(z+x), 0, (-z-3)].[-x, -y, 1]
After that I substitute x = rcos(θ), y = rsin(θ), z = 0.5r^2
Thus ∫(0-2)∫(0-2pi) (∇xF).Nr dθdr
But I can't seems to get the answer. Can anyone help? Help would greatly appreciated :)
Looks okay. What did you get for the answer or where are you getting stuck?
ok so its ∫(0-2)∫(0-2pi) (∇xF).Nr dθdr
Therefore its:
∫(0-2)∫(0-2pi) -xz-x^2-z-3 dA (Using x = rcos(θ), y = rsin(θ), z = 0.5r^2)
= ∫(0-2)∫[(0-2pi) -0.5r^3cosθ - r^2cos^2(θ) - 0.5r^2 - 3]r dθdr
Im not sure is my steps correct? Jus a little problem with integrating cos^2(θ).
Furthermore, I've used ∫F.dr to do a check and the answer seems to be 0. Is this correct?
Looks good, but I got -20 pi for the answer both ways.
To integrate cos^2(θ), use the trig identity cos^2(θ)=[1+cos(2θ)]/2.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
