Vertical Height Between Two Climbers
  • Thread starter Thread starter Doug Desatnik
The discussion centers on a homework problem involving kinematics in two dimensions, specifically calculating the vertical height between two climbers when a first aid kit is thrown. The initial velocity of the kit is 6.93 m/s at a 66.5-degree angle, and it is caught with a vertical speed of zero. Doug initially calculates the height using the equation Y = (V_final^2 - V_initial^2) / (2A), arriving at a height of 2.45 meters. He later realizes the question asks for the maximum height of the projectile and seeks clarification on rearranging the equation Y = (V^2 - V_initial^2) / -2g for this purpose. The discussion highlights the importance of correctly interpreting the problem and applying the appropriate kinematic equations.
Doug Desatnik
Answer Verification...*Please*
Hi Everybody,
I am having a problem with a homework question and think that I have finally got it right this time! Can somebody verify my work on this problem and let me know if I did indeed do this problem correctly? If not then can anybody help point me in the right direction and get me back on track?
The HW deals with Kinematics in 2-Dimensions
THANK YOU!
- Doug
The Question
A rock climber throws a small first aid kit to another climber who is higher up the mountain. The initial velocity of the kit is 6.93 m/s at an angle of 66.5 degrees above the horizontal. At the instant when the kit is caught, it is traveling horizontally, so its vertical speed is zero. What is the vertical height between the two climbers?
My Set-Up of Variables
V_initial = 6.93 m/s
V_final - 0 m/s
A = 9.80 m/s^2
Y = ? (SOLVE FOR)
T = ?
My Equation & Work
V^2=V_initial^2+2AY --> Y = (V_final^2 - V_initial^2)/2A --> (0^2 - 6.93^2)/2(9.80) --> 48.02/19.6 --> 2.45m
I wanted to try this question using this LATEX code, so here it is:
My Variables
V{0} = 6.93 m/s
V = 0 m/s
a = 9.80 m/s^2
My Equation
V^2=V{o}^2+2aY
My Work
V^2=V{o}^2+2aY --> Y=V^2 - V{o}^2/2a --> Y=(0^2 - 6.93^2)/(2)(9.80) --> 2.45m
LATEX is really cool! It will surely take some time to get used to but this is really a nice function!
Ok, so after looking at this problem a bit differently, it is obvious that what the question is asking for is the max height of the projectile, right? In that case then the equation would be:
V^2=V{o}^2-2gy
V{o}=6.93 m/s
V=0 m/s
g=9.80 m/s^2
y=?
I guess then my question becomes a simply math (algebra) problem... How do I rearrange the equation above to solve for the height, Y?
Is it like so?
Y=(V^2-V{0}^2)/-2g
- Doug
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
