Calculating Electric Field in Water-Filled Container: What is the Best Method?
  • Thread starter LuGoBi
In summary, the conversation discusses calculating the electric field generated by a charge on the bottom of a container filled with water, taking into account the differences between the electrostatic constants in air and water. The method of images is mentioned as a way to solve this problem, but the speaker suggests consulting a textbook for more information. There is also a mention of using Gauss' Law and trigonometry as other potential approaches.
LuGoBi
This is killing me. I have an electrical charge in the air and below it I have a container filled with water. How do I calculate the electric field generated by the charge on the bottom of the cointainer? Bear in mind the electrostatic constant in water is different than from air.
Assuming the surface of the water is like an infinite plane, this is a standard image problem treated in most textbooks.
Could you ellaborate, then?
I can't go through the whole method of images.
You may have to look at a book.
smells like homework?
Excuses me, pam (or others), but doesn't the method of images require that the boundary region be a (grounded) perfect conductor?
Treating the problem in a brute-force manner (Gauss' Law, Cartesian coordinates), this doesn't sound TOO bad. You just need to invoke some pretty clever trigonometry to account for the surface of the water.
FAQ: Calculating Electric Field in Water-Filled Container: What is the Best Method?
1. What causes "Very Annoying Problem"?
The cause of "Very Annoying Problem" can vary depending on the specific problem. It could be due to a malfunction in a system, human error, or a combination of factors.
2. How can "Very Annoying Problem" be prevented?
The best way to prevent "Very Annoying Problem" is to identify the root cause and take measures to address it. This could involve implementing new protocols, updating systems, or providing additional training.
3. What are the consequences of "Very Annoying Problem"?
The consequences of "Very Annoying Problem" can range from minor inconvenience to serious issues, depending on the severity of the problem. It could result in financial loss, safety hazards, or damage to equipment.
4. Can "Very Annoying Problem" be fixed?
Yes, "Very Annoying Problem" can be fixed. It may require troubleshooting, implementing solutions, or seeking assistance from experts in the field.
5. How can I report "Very Annoying Problem"?
If you encounter "Very Annoying Problem", you should report it to the appropriate person or department responsible for addressing the issue. This could be your supervisor, IT team, or customer service representative.
