Understanding Isolating Transformers: Basic Concepts and Applications
Isolating transformers typically maintain the same voltage due to their 1:1 turns ratio, providing safety through galvanic isolation between primary and secondary circuits. They are commonly used in bathroom shaver circuits to prevent electrical shock, ensuring user safety in wet environments. For the transformer example given, with 5000 turns on the primary and 8000 on the secondary, the output voltage can be calculated using the turns ratio. The discussion emphasizes the importance of showing work for homework problems to facilitate understanding. Overall, isolating transformers serve critical safety functions while allowing for voltage adjustments as needed.
LitKey
Might be some simple questions for you guys but I'm just in grade 9
1. Do isolating transformers change the voltage in a circuit?
What I know is that isolating transformers have the same amount of coils because it needs to be safe.
2. Explain why an isolating transformer is often used in a bathroom shaver circuit.
3. A transformer has 5000 tunrs on its primary coil, and 8000 tunrs on its secondary coil.
If the input voltage is 230 V, find the output voltage.
- Lit
- Lit
Welcome to the PF.
You will need to show more of your work on #2 and #3 before we can help you. That's how we handle Homework Help here at the PF.
For #1, you are mostly correct. In general, an "isolation" transformer will be a 1:1 transformer, with the main talk of galvanically insulating the primary from the secondary. However, an "isolating" transformer just means that the primary is insulated from the secondary, so the turns ratio could be whatever is needed for the application.
Please give us your thoughts on #2 and #3. For #3, what is the voltage ratio equation for a transformer, in terms of the ratio of the number of turns primary/secondary?
3. A transformer has 5000 turns on its primary coil, and 8000 turns on its secondary coil.
- Lit
Welcome to the PF.
My thoughts for #2 is that if its used for a bathroom shaver circuit, it needs to be very safe so that no harm can be procured in our face. Not sure if that's quite the answer though because the question says "explain". This is just 2 sentences.
#3. I can give you a short summary. If its a step down transformer with a 4 to 1 turns ratio, and the input voltage is 480, the output would be 120. So you're dividing with 4. As you do with the primary and secondary coil. I think a step up transformer would be the other way around. 1 to 4 turns = (1x4 = 4.) 120V and 480V. (120Vx4 = 480V.)
And for #1, if I understood right, the voltage doesn't change due to safety reasons. You, yourself choose a permanent voltage and change it manually.
You have the turns ratio equation correct for #3, so now put in the turns numbers that they list, and calculate the output voltage answer for #3.
Alright, I'll do that in a min. But is my answers for #1 and #2 correct?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
