Very Easy Taylor Series Approximation Help
Farzan
Approximate f by a Taylor polynomial with degree n at the number a.
f(x) = x^(1/2)
a=4
n=2
4<x<4.2
(This information may not be needed for this, there are two parts but I only need help on the first)
Summation f^(i) (a) * (x-a)^i / i!
Derivatives...
x^(1/2)<br /> 0.5 * x^(-1/2)<br /> -0.25 * x^(-3/2)
So the Taylor series of order n=2 should be...
2 + 0.25(x-4) - (1/64)(x-4)(x-4)
Now, my question...
To find the approximation of square root of x, do I just plug in 4 to that?
That would make most of the terms zero, leaving me with 2
Does this mean that whenever the Taylor series is centered at a number, the first term is the approximation?Ugh, sorry for the failure using tex tags :( It's my first post here
Yes. Exactly. If x=a the first term IS the approximation. The usual game is to approximate something like 4.1 using the series.
I think Dick is interpreting the question differently than I am.
What you have: 2+ (1/4)(x-4)- (1/64)(x- 4)2 alread is the quadratic approximation to \sqrt{x} around x= 4.
Putting x= 4 would just give you the obvious \sqrt{4}= 2.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
