Very hard trig solution that is way too long
  • Thread starter Thread starter tdude
    Hard Trig
The discussion revolves around proving the equation sin(5A) + sin(2A) - sin(A) = sin(2A)*(2*cos(3A) + 1). Participants explore various trigonometric identities and methods to simplify the proof, with one suggesting the expansion of the right side and cancellation of sin(2A). A key identity, sin(A)*cos(B) = sin(A+B) + sin(A-B), is highlighted as a useful tool for simplifying the problem. After some back-and-forth, the participants confirm that using this identity makes the solution significantly easier. The thread concludes with a participant expressing satisfaction with the solution and requesting the thread to be closed.
tdude
Prove that
sin(5A)+sin(2A)-sin(A) = sin(2A)*(2*cos(3A)+1)
sin(2A) = 2(sin(A)cos(A))
cos(2B) = cos2(A)-sin2(A)
cos(A+B) = cos(A)cos(B) - sin(A)sin(B)
sin(A+B) = sin(A)cos(B) + sin(B)cos(A)
I can't find any other way than to just decompose the whole thing into sinA or cosA, and that is really long and usually full of mistakes. Is there something that I'm missing here? Something that makes this proof a lot easier?
Well, yeah, somewhat easier. Expand the right side and cancel the sin(2A) on both sides. Now expand sin(5A)=sin(2A+3A). Then maybe use sin(3A)cos(2A)-cos(3A)sin(2A)=sin(A)? It goes a bit easier, yes? Hope I don't have a typo in there.
Do you know the identity
sin(A)*cos(B) = sin(A+B)+sin(A-B) ?
Use on the right side for 2*sin(2A)*cos(3A).
ehild
ehild
are you sure that's correct?
that's what's on wikipedia.
if it is however, it could help.
My mistake, I forgot the division by two. Use Wiki's formula, it really helps! You will be surprised, how easy the solution is. :)
ehild
aight, got it. all is well! Close thread please!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
