Video/audio data rates for avi files
  • Thread starter Thread starter Pengwuino
    Data files
The discussion centers around confusion regarding the calculation of overall data rates for a video file. The file in question is an AVI format with specific audio and video characteristics, including a size of 102,892 KB, a resolution of 640x480, and a duration of 11 minutes and 36 seconds. The audio has a bit rate of 127 kbps, while the video is at 147 kbps. The participant calculated the overall data rate to be approximately 1200 kbps, but noted that the combined audio and video bit rates only total around 300 kbps, leading to confusion about the correct method for calculating data rates. The conversation highlights the discrepancy between expected and actual bit rates, suggesting that the video should reflect a higher data rate based on its size and duration.
Pengwuino
Ok something is confusing me, I have this file here...
.avi
102,892 KB size
640x480
11m:36s
Audio:
Bit rate: 127kbps
MPEG Layer-3
Video:
23 frames/econd
147kbps
24bit
XVID Compression
Now I'm kind of confused... I calculated the overall data rate to be 1200kbps or so... yet those only seem to add up to 300kbps... how are you suppose to calculate this stuff?
Computer science news on Phys.org
audio or video rate?
Yah it doesn't add up dduardo :) The video should have been 1200kbps using the real size and time but the two bit rates don't add up to that.
In my discussions elsewhere, I've noticed a lot of disagreement regarding AI. A question that comes up is, "Is AI hype?" Unfortunately, when this question is asked, the one asking, as far as I can tell, may mean one of three things which can lead to lots of confusion. I'll list them out now for clarity. 1. Can AI do everything a human can do and how close are we to that? 2. Are corporations and governments using the promise of AI to gain more power for themselves? 3. Are AI and transhumans...
Sorry if 'Profile Badge' is not the correct term. I have an MS 365 subscription and I've noticed on my Word documents the small circle with my initials in it is sometimes different in colour document to document (it's the circle at the top right of the doc, that, when you hover over it it tells you you're signed in; if you click on it you get a bit more info). Last night I had four docs with a red circle, one with blue. When I closed the blue and opened it again it was red. Today I have 3...
